Just figuring out turning in manufacturing, playing with changing direction to back to front, and pretty sure I've found a bug.
So, very simple shape. I've got a custom cutting tool, which is angled with a flat face on one side, R1mm at the end, so that I can cut profiles and face off the part being cut. Because this is woodwork, I want to cut with the grain or downhill. If I create a finishing toolpath front to back, so cutting towards the chuck and going uphill - toolpath generates fine. If I try to do the other way, back to front, it doesnt generate a proper path.
However! If give it a turret angle of + or - 0.1 deg, it works fine. I wondered if fusion didnt like the flat end radius for some reason, so I tried a slight point on the end, rather than being fully rounded, but got the same result (not shown). It seems to be just very specifically a flat face, moving back to front, that it doesnt like. So, pretty sure this is a bug?!
