Announcements
Turning a Square Object into a Sphere
beukes.ruan
Observer
beukes.ruan
Observer
Observer
I'm trying to cut/remove the square objects - The idea is to have a perfect sphere with multiple bodies.
My design started of as a square consisting of 10 seperate bodies.
The bodies which are already rounded off I simply extrude/cut without any issues, however i'm unable to do so with the remaining square sections.
Any advise would be greatly appreciated.
Rushikesh.kadam
@beukes.ruan is it possible to share the file? Sharing it may help to get a quick solution.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
beukes.ruan
Observer
Observer
Hi Rushikesh.kadam,
Please see file attached.
TheCADWhisperer
Revolve - Intersect.
Edit: After taking a deeper look - I would have modeled this very differently.  In my opinion you are doing too much work.  But anyhow - attached is the Revolve.
beukes.ruan
Observer
Observer
Thank you very much TheCADWhisperer.
I'm still n newby to CAD/Fusion 360 so it's all a learning curve.
Thanks again.
