Announcements
Turn off "Text Commands" Panel on startup
rventura.57
rventura.57
When I start Fusion360, there is always a "Text Commands" panel at the bottom of the screen. I never use Text Commands so always close this panel. Is there an option I can set so that Fusion opens without this panel opening?
Oguzhan_Sezer
How do you turn it off? Can you try this way? It will open according to the option you last used.
Oğuzhan SEZER
Manufacturing Engineer
Technical Support Specialist / Artı & Artı Teknoloji Hizmetleri
rventura.57
Hi Oğuzhan (I hope I got that right).
Thanks for your reply. That worked perfectly! Easy when you know how.
Many Thanks.
Oguzhan_Sezer
You're welcome.
Oğuzhan SEZER
