Turn off "Text Commands" Panel on startup
rventura.57
rventura.57
When I start Fusion360, there is always a "Text Commands" panel at the bottom of the screen. I never use Text Commands so always close this panel. Is there an option I can set so that Fusion opens without this panel opening?
Oguzhan_Sezer
How do you turn it off? Can you try this way? It will open according to the option you last used.
Oğuzhan SEZER
Manufacturing Engineer
rventura.57
Hi Oğuzhan (I hope I got that right).
Thanks for your reply. That worked perfectly! Easy when you know how.
Many Thanks.
Oguzhan_Sezer
You're welcome.
Oğuzhan SEZER
