Trying to save a NC file to a network share saves to an absurdly long local directory chain instead.
oldernstone
oldernstone
On the left is the directory I've selected to output a .nc file to and on the right is the directory it's actually being saved to. The directory I've indicated is not being saved to at all. ncsave.pngncsave2.png
seth.madore
Is this on a Mac or PC?
We've had some reports of this issue and are currently investigating, sorry for the issues.
CAM-24824 for reference
Seth Madore
jeff.pek
From the path, looks like it's windows.  A couple of things:
1) Windows uses backslashes (\) as path separators, e.g., \\server\share\foo\bar. See if shifting to that makes a difference.
2) Try mapping a drive to the share, so that you can use standard-looking paths, e.g., z:\foo\bar.
As Seth says, we are aware of some problems in this area, which are being investigated.
Jeff
oldernstone
Manually replacing the forward slashes with reverse does fix the issue and the .nc file correctly saves to the shared network directory.
shred2
It's definately a Fusion360 thing.  No other software does this.  You can fool around with slashes and drive letters and mapped drives and whatnot, but it will just come back the next time you reboot or exit Fusion.
