Fusion Support
Trying to extrude edge of flange creates a new body even when I select "Join"
3 REPLIES 3
robLBYMJ
124 Views, 3 Replies
I am working on a part where I start with the primary flange, create a flange off that, and then try to extrude one of that flange's edges.  It's always creating a new body!  I don't want to create a new body, I want the extrusion to be a part of the original part.   This worked in the last version of Fusion360.
Sorry if this issue is a duplicate of what somebody else posted.
3 REPLIES 3
jeff_strater
in reply to: robLBYMJ
it works for me in a simple test.  Could be model specific - can you share your model?
Jeff Strater
Engineering Director
TheCADWhisperer
@robLBYMJ
Do you have the correct Component active?
Can you use the Flange tool rather than Extrude?
robLBYMJ
Hm.   Seems as if my Fusion 360 was somehow between updates or something, because I restarted it (to install update) and then everything worked.   Odd.
