Fusion Support
Trying to Cut Holes In Solid - Is This A Software Glitch?
8 REPLIES 8
Message 1 of 9
glencandle
243 Views, 8 Replies
I have created a grid of bodies that I want to use to cut a hole in a larger object.   I'm using a Combine modify tool, and I've got all my holes selected as you can see below, but as soon as I hit OK nothing happens.
I'm stumped, I've tried this a dozen different ways and I'm either having a total brain fart of the software is glitching.
Would love to know if it's me or Fusion, thanks!
Tags (3)
8 REPLIES 8
Message 2 of 9
davebYYPCU
in reply to: glencandle
Hide the kept Tools - in the component visibility.
Might help....
Message 3 of 9
glencandle
in reply to: davebYYPCU
Oh man, definitely worked too long today. I feel very dumb. Thank you!
Message 4 of 9
g-andresen
just try it this way
günther
Message 5 of 9
glencandle
in reply to: g-andresen
This is a cool solution. The only issue is the grid pattern of holes isn't as tight as I need. (It doesn't alternate half a diameter along the x-axis as I have done.) But I like the tidiness of this approach nonetheless.
I've never used the Patch tool before. What does it do/mean exactly?
Message 6 of 9
g-andresen
change the pattern direction
The extrusion with the option "Cut" is limited by the object Surface Body ("To Object") .
In the following pattern, only those features are duplicated that are completely within the area of this surface.
günther
günther
Message 7 of 9
glencandle
This is quite brilliant, thank you for walking me through that. A definite enhancement to my skillset.
Message 8 of 9
g-andresen
Then please also mark it as an accepted solution.
This will make it easier for future readers to find their way around.
günther
Message 9 of 9
glencandle
Done. Didn't realize there could be two accepted solutions, thanks for the heads up.
