Announcements
Trouble with solid works 2021 files loading
wm.bobm
wm.bobm
Has anybody else had trouble opening solidworks 2021 files? When we try to open them it tells us file is not compatible. Is there a new update out yet so fusion will open the new 2021 files and we dont have it yet?
seth.madore
2021 is not yet supported by Fusion, but we hope to have a release out fairly soon to address that.
Seth Madore
wm.bobm
Thank you Seth. Do you know if they have any time frame on when this will happen? I'm asking because a lot of the engineers we deal with use solidworks and we like fusion for our programming so this is a bit of a hassle for us.
seth.madore
Drop a PM to @jeff.pek he may be able to hook you up with a workaround
Seth Madore
Was this ever fixed?
Hi, do you know when this may be sorted causing us a lot off issues having to save all models out as Para solids instead of the native solid works 2021 files.
