Trouble editing countersink parameters
I need to enlarge the countersink diameter for a 4-40 flathead screw. I now know that the heads are are larger with a hex key drive.
That parameter is gray when "clearance" is selected. Elsewhere I saw that you should edit this in the change parameters area. I was able to do this once, but as I played around, I got an error when changing the angle, diameter, depth, etc.:
The above is after changing the angle from 82 to 81, and then back to 82 for a group of holes (Hole 4). It also happened on a single hole, Hole 1.
This is beyond messy; couldn't we just edit all the parts of the feature, when creating the feature?
