Fusion Support
Trouble Converting Mesh to Organic Solid
6 REPLIES 6
wernickar
187 Views, 6 Replies
I am attempting to convert a surface mesh (STL) to a solid body using the Organic option. The option failed and recommended to use the "Create Base Feature" option, however I do not see the option. I checked for it under the Design>Create menu. I also tried repairing the design surface mesh, however the repair tool either removed the entire mesh, or removed parts of the mesh depending on the setting used. The STL file is quite large which may be part of the issue. Please let me know if you can help.
Labels (1)
6 REPLIES 6
jhackney1972
in reply to: wernickar
Please attach your STL file.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
wernickar
I cannot attach it since the geometry is proprietary.
TrippyLighting
Based on the complete lack of information you have provided so far, we cannot provide any meaningful help.
Peter Doering
Warmingup1953
This where it is for me:base.jpg
TheCADWhisperer
@wernickar
Can you Attach a dummy file that exhibits the same behavior as your proprietary data?
wernickar
The Create Base Mesh Feature is not there in my software. Is it part of an extension?
Also, I am working on seeing if there is a geometry that I am allowed to send that is having the same issues.
