Announcements
Triangle shape detent in one face of object or surface
cfrazeur52
cfrazeur52
I am trying to produce a triangle shape detent on the front surface of the object below.  I would like to detents to be cfrazeur52_0-1681582149634.png
 inches apart.
to produce a drawing that has a set of detents for a snap adjustment for various depths between two parts.
TheCADWhisperer
Are your sketches fully defined?
cfrazeur52
I had to subscribe to Fusion 360 as I was running out of editable drawings.  Attached is my drawing.  I would like the detents to continue the full length of tube in .25" increments.  The detents look like this >, similar to ratchet or cam.
Chris Frazeur
503 705 2636
davebYYPCU
Similar to this?
Fix yellow and red icons with Undo before saving.
Might help....
