Transparent background option not working
Lately I stumbled into this issue, when I want to export my render into a png with no background, I'm not able to use the options in the capture imagine window and theres no background transparency option the rendering settings anymore, does anyone has a solution to this?
tallisb
Hello-
There are a couple of ways of doing this...  If you are doing a Cloud Render, once the cloud render is complete, you can select the image from the rendering gallery at the bottom of the screen.  When the image dialog appears, click on the Download icon and you will see the option for the Transparent Background.  (see image01 attached)
If you are doing a Local Render, the Transparent Background option shows up in the Local Render dialog.  (see image02 attached)
Brad Tallis
Fusion 360 Technical Specialist
