Hi y'all!
So I have an assembly, was done in CAD not in F360, I diligently convert all bodies into components and make my exploded view in the animation workspace.
I make a drawing out of it, i put parts numbers on... everything works fine.
However I also need a 3D dwg file of the exploded assembly, meaning I need to basically "fix" the position of the animated components and export it that way.
Is there any way I could do it?
Also, and this is secondary in importance, is there a way I could automatically add to the parts table (like the one you can do in the Drawing tab) the dimensions of the part? Meaning the XYZ max dimensions?
