Hello everybody reading,
Im not sure if this is the correct forum but Ill post my issue anyway, before I got in touch with fusion 360,
I designed a fin-like object in tinkercad it looks like this
https://www.tinkercad.com/things/aw5u6nrc05U-fin-mx-218-v2
Now I tried to export it to fusion 360 bcs I need to put it on a design I then want to put in CFD.
But only a small fraction of the object got exported
(Yes it has a triangular hole in the back)
Now my problem with using the .stl file is that fusion breaks it down in very small surfaces, as it does it with any mesh, and this creates a lot of problems in further usage (like putting in in cfd)
Could anyone pls tell me what options I have if I dont want to have an object with countless small surfaces which are hard to use as objects?
