Fusion Support
Timeline drop down menu primary secondary monitor
1 REPLY 1
contact66RVF
69 Views, 1 Reply
I am running a primary FHD monitor with a secondary 4K monitor above with displays extended one above the other on Windows 10
Right clicking on an item on the timeline, the menu goes down off the bottom of the 4K monitor to a place where it cannot be seen.
Restarting and performing view->reset default layout does not fix it
Hence I have to take fusion out of full screen maximised each time I want to right click on a timeline feature
It would be really good if this menu pop-up went up and not down
1 REPLY 1
contact66RVF
in reply to: contact66RVF
Found the answer or at least a solution.
Setting display option make this my main display for the external monitor fixes the timeline menu from going off the bottom of the screen.
