Time Service Certificate Fail
I am trying to run Fusion 360 on my Surface Pro4, I have used it before I had to reimage my PC.  I am now getting an error when launching that is not listed on the forums.
2017-10-11T16:47:33.698Z [Fusion360:9672, 3064] [AdWebServices.TimeService INFO] Getting time from server https://time.akamai.com
2017-10-11T16:47:33.779Z [Fusion360:9672, 3064] [AdWebServices.TimeService ERROR] TimeService::SslError: CertificateSignatureFailed (4): The signature of the certificate is invalid. Certificate:
I can manually browse to the time server without issue, I have checked and the Verisign Root certificate is enabled
I have attached the complete WebServices Log file
paul.clauss
Hi @Anonymous
Thanks for posting! I am sorry to hear that you are unable to access Fusion 360.
As you recently re-imaged your PC, I am wondering if Fusion is trying to pull a cached certificate when opening. Have you performed a clean uninstall and reinstalled Fusion 360 since the re-imaging? I would begin troubleshooting by doing so.
If this does not resolve this problem, I would like to have a look at all your log files. Please gather them using the procedure at this link and email them to me directly at paul.clauss@autodesk.com - I am happy to have a look!
I would also like to have a look at the error message you are receiving when opening Fusion - would you mind attaching a screenshot of this message to this forum thread?
Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
Paul,
Attached is the Screenshot.  After re imaging (actually it was a full format and reinstall of the OS) I did a fresh install of Fusion360 as it was as if it never existed.  I will send an email with all the logs in a minute.
Robert
Paul,
The re-image was really a full format and reinstall of windows, so technically Fusion never existed when I installed it.  I am sending the log files now. the error is attached.
I have just tried doing a full removal (using your tool) and reinstall.  It installs without error, then when it tries to load i get the same error again.  Looking through the install log there are warnings about the network. Specifically regarding the SSL commands used in the python installer.
paul.clauss
Hi @Anonymous
Thanks for the response and sending the files over!
The first thing I noticed was that you are receiving the generic "sign in failure" message - this can be triggered by a number of factors. Often this message is due to network issues and I would begin troubleshooting by looking through the links below to ensure that your network is all set up correctly. I did notice that you are working on a proxy server - please pay special attention when checking your proxy settings.
One specific server that the proxy appeared to be blocking in your log files is the https://js.prd.fusionapi.autodesk.com/hds/fusion360.json address. Please ensure that the *fusionapi.autodesk.com domain is whitelisted by your proxy and firewall/antivirus.
If none of this works, we could try deleting the loginstate.xml file - this often resolves log in failures in Fusion. To delete the loginstate.xml file;
  • Close Fusion 360
  • In windows explorer, browse to %localappdata%\autodesk\web services
  • In the Web Services directory, right lick on the LoginState.xml file and select delete
  • Restart Fusion 360
Hopefully this helps! Please feel free to send over the new installation log showing the SSL command errors - I am happy to have a look.
Paul Clauss
