Announcements
Threading a cylinder
sales3MPAD
sales3MPAD
I created a body using the polyline to create half of a cylinder with a number of features.  I revolved it around the x centerline.  This gave me a body that looks like the part I want.  However I need to thread one end of one of the cylinder faces.  When I select the part of the cylindrical part of the body I want to thread it deselects the cylinder and I cannot select a face to thread.
I don't know if it's an issue that I used the revolve command to create it or what.  I do know I know how the thread command should work because I created a simple cylinder by extrude then selected thread, and it worked exactly as expected.  So I am left to feel it has to do with how I created the body.
Any input would be appreciated.
Replies (10)
jeff_strater
most likely, you are correct.  You have somehow not actually created a cylinder.  Using Revolve, you need the centerline and the outer line to be parallel.  If they are not quite parallel, then the result is a cone, and you cannot apply a Thread to a cone.  If you share the design, it will be easy enough to tell.
Jeff Strater
Engineering Director
sales3MPAD
I think that is correct.  I found one end was 0.0005 bigger.  Now to figure out how to adjust that line in the sketch before revolving.
sales3MPAD
Well I fixed the one problems and apparently created another.  Some how I managed to delete something and now I get redefine reference plane errors, BUT everything I have watched, I can't seem to enable that function.
TheCADWhisperer
sales3MPAD
I seem to have fixed the reference plane issue by starting over, but now it's back to it still won't revolve.  It looks like all the lines are connected together. but it seems a profile is not made.
TheCADWhisperer
You are missing several Horizontal and Vertical constraints.
You are missing many dimensions?
If you click and drag the top "horizontal" line - what do you observe?
TheCADWhisperer
After looking deeper - I recommend that you create ONLY one line at a time and repost here for comment BEFORE creating your next line.
TheCADWhisperer
Dimension and fully define each line as you go - you should have no blue lines or white dots...
TheCADWhisperer
Also, turn off 3D Sketch...
sales3MPAD
Thanks.  I  redrew the entire part and no everything works as expected.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
