Hi there!
A couple a years ago (June 2019) i designed a adapter ring with a M40x1 6H pitch.
Now i need to design a new product, with a M40x1 pitch, which should be fine, at least i thought so.
In the thread drop down were you set diameter, 40mm is selectable, but not M40x1, smallest is M40x1.5.
Why is this?; same goes for M26, but with only 1 option, pitch 1.5. So, when creating the drawing, and i want to state the thread and pitch, i don´t get the accurate dimensions and sizes, because the thread function ADDS the chosen diameter to the part (3d model), even when exporting to a step file.
So, anyone who might have a clue why some pitches got removed?
Finally, don´t suggest to me how to create my own what ever i want pitch by using coil and sweep. That i do when design polymer/plastic products for molding. The whole point of the function is to get the representation on the 2d drawing and accurate dimensions for the 3D model, where the pitch is used.
