Announcements
Thread callout not wokring.
jul936
jul936
I was trying to add hole and thread callouts to my drawing, and only the hole callouts will appear. I am using the hole and thread command,  and not using extruded features (although I have tried that as a troubleshooting step). I can select the hole and it will give my drill size and drill depth, but when I select the thread it gives me a blank note for me to type. If I force the type to hole and thread, I cannot select the lines for the thread and the hole lines still do not produce thread callouts, just the ones for holes.
I am using the latest version of Fusion, an up-to-date version of Windows, it has this problem with and without templates, and hole callouts work fine, just not thread callouts.
ClintBrown3D
Hi @jul936
The hole and thread note tool currently only works on holes with threads that are part of a hole feature.
The good news is that we are close to finishing work on improvements to the hole & thread notes tool that will accommodate the note type that you described. You can expect to see an update in an upcoming release.
Have a look at the public roadmap under "Annotations".
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
jul936
Ah, I misunderstood. I thought you used the hole and thread commands separately. I didn't realize you could tap holes directly with the hole command. Thank you!
