I tried restarting the com and still get the error.
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.process - WARNING :: Exception in Update The Registry is not found
2021-03-03 10:15:23,605 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026F81E68288> #
2021-03-03 10:15:23,606 - MainProcess(23300) - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2021-03-03 10:15:49,381 - MainProcess(23300) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2021-03-03 10:15:49,382 - MainProcess(23300) - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: # #
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000026F825C3C48> #
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\isaac.wong\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from **deleted**\a95f8c5ccd1169cf841c8219266ac15fc1536633\resources\buildinfo.json
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20201218103501
2021-03-03 10:15:49,383 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2021-03-03 10:15:49,384 - MainProcess(23300) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: **deleted**\a95f8c5ccd1169cf841c8219266ac15fc1536633\resources
2021-03-03 10:15:49,384 - MainProcess(23300) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
