Update: the issue isn't the shape but that the first uses a spline and the second one uses lines. It seems you can only offset curves (splines)
When I do a more complex shape like this then I get a seam after revolving it
But when I do this simple shape I do not get a seam. Why is that and how can I fix it?
I need the seam to make an offset of the shape later on
An export of the last sketch is attached
