Announcements
The tool bar on the top and timeline on the bottom go complete black after latest update.
spike.moa
spike.moa
After the latest update the toolbar is completely black now.
It was working before the update.
The buttons are still there and functional but just can not be seen!
Tried: Updated graphic driver to the latest.
Tried: Set graphics driver in fusion to DX11 DX9 Opengl
It is serious. I can almost do nothing now!
Please help!
[GPU Information]
GPU Device: Intel(R) HD Graphics 630
GPU RAM: 128 MB (Integrated card)
GPU Driver API: OpenGL Core Profile 4.6
GPU Driver Version: Unknown
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
mohammed.aliTDPXK
Hello @spike.moa ,
Sorry for the trouble you are facing.
Can you try the below workaround?
One potential workaround is to force Fusion 360 to use software rendering by setting a system Environment Variable.
  1. Right-click on My Computer/This PC on the Desktop or in the Start Menu and select “Properties”
  2. In the left column of the System window that appears, select “Advanced System Settings”
  3. Within the System Properties window that appears, click “Environment Variables” in the bottom right
  4. Within Environment Variables, click “New…” under the System Variables section
  5. For Variable Name, enter QT_OPENGL
  6. For Variable Value, enter software
  7. Click OK to save the new variable
  8. Launch Fusion 360
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
Let me know if this helps
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
