The selected face could not be offset
Very new to Fusion 360, and need a bit of help here.
I'm having trouble with creating a shell. It lets me make an external shell - but not internal, and I get the error message 'The selected face could not be offset'.
It is for a bicycle tyre, which has been revolved from a sketch and I now need to remove the interior i.e. make it a shell.
Thanks in advance!
g-andresen
please share the file
File > Export > save as f3d on local device > attach to next post
günther
Attached here, vielen dank
jhackney1972
Due to the interior sharp corners, I believe the shell is restricted to a small wall thickness.  The max I could tweak out of it, after modification of your sketch slightly, was .9 mm.  Model is attached.
John Hackney, Retired
TheCADWhisperer
Here is my attempt with a bead on the tyre.
Shoould be able to get whatever wall thickness you need.
