the remaining files blocking reinstallation
epoki-wyrywac0g
Observer Observer
epoki-wyrywac0g
Observer
Observer
How to reinstall fusion360?
sutherland-
Hi @epoki-wyrywac0g
Here is a link on how to manually uninstall F360.
Please try to find a solution here before posting on forums.
Simply type in the issue in the highlighted box seen below:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
jhackney1972
The following webpage will give your links to both methods of uninstalling Fusion 360.
John Hackney, Retired
epoki-wyrywac0g
Observer
Observer
Problem solved. Fusion360 works fine again.
