Announcements
The hole is created split by half
I am creating a standard hole on a body created by revolving a shape. On one face of the body hole is created split with a diameter line (which is created as a physical line) and consists of two arcs. The shape itself looks like underneath the face it was intended to start from, and the hole is barely visible.
Creating holes on other faces does not result in such a behaviour.
Please help mу to find out what is wrong with the face/body.
The file with problemous model is attached.
Replies (16)
TrippyLighting
The first thing I would do is to fully dimension and constrain all of the sketches. Then we can discuss the next step.
That would probably be to replace the cylinder primitive with a sketch/extrude or revolve.
Then I'd use a sketch and define (constrain/dimension) a sketch point where we can locate the hole.
Then create the hole.
I suspect then it'll work just fine.
TheCADWhisperer
Would you be willing to start over from scratch if given step-by-step instructions?
harpo3196
Will this work
Steps Offset plan, Sketch PCD on new plain, Extrude cut holes
TrippyLighting
Yes, and no. Yes, because you can create some geometry.
No, because th3e whole approach to design this object is flawed right from the first sketch.
This part should be centered on the origin but isn't. Then, as explained above there are more design technique flaws.
None of these are difficult to address.
harpo3196
Here is how I would have designed it. mine that the original was from a canvas
In Australia, In Lock Down, Nothing better to do
TheCADWhisperer
Your attempt does not match the drawing dimensions.
harpo3196
Yes it was off canvases and the numbers were eye balled.
TheCADWhisperer
@harpo3196 wrote:
...the numbers were eye balled.
Why not use the given dimensions?
harpo3196
Late at night, in lock down, Got a base diamension wrong, But still shows a cleaner way of CADing it. Took 2 minutes to mod.
TheCADWhisperer
@Anonymous
If you want to know how to do it right - post back.
harpo3196
Stop pushing your you tube channel and show me here
TrippyLighting
The link to @TheCADWhisperer's youtube channel is in his forum signature. That does not mean he's pushing it.
He attached his approach to his last post. Download it, study the timeline features and sketches he's created and learn.
Ask questions if you don't understand.
TheCADWhisperer
@harpo3196  I am now confused, are you the same person as @Anonymous ?
My communication is intended for the original poster - @Anonymous .
TheCADWhisperer
Actually, I haven't given any information on the technique that I would use yet.
I'm still trying to determine if the OP @Anonymous is still here and interested in seeing my technique.
A lot of confusion going on here.
geometry remain always a tough task for me am really very bad in geometry and unfortunately face the same problem would you please help me regarding this
TheCADWhisperer
@Anonymous wrote:
.... face the same problem would you please help me regarding this
@Anonymous
The same problem?
Is this a school assignment?
