Hi i have been trying to learn Fusion 360 for two weeks now to be able to design things to 3d print. I learn mostly from some you tube tutorials. I have been able to design some complex ( for me) assemblies. I am not an engineer or designer. So far i am very happy with my progress and trying to learn more advanced techniques in designing and also fusion.
Yesterday, i watched a respectable tutor who strongly recommended using multiple sketches instead of trying to fit everything in one sketch and clutter. It made sense and wanted to try it in my new project. An enclosure for a screen display and a bunch of leds surrounding it (sim racing dashboard with screen and leds). I plan to create 2 components. Component 1 : Face plate with window for screen and holes for leds and screws. Component 2: Box to accommodate screen arduino cables etc.
As i am also new to 3d printing I can not calculate tolerances accurately. So I Created a mock up component Face plate trial. Which will have 4 additional leg if the screen will fit in as intended to with the dimensions i put in Cad. and use those dimensions to create the box. If it will be printed OK then i will remove those legs and print the final face plate. This is when i realized the issue i mentioned in the title.
1st sketch should be only face plate with accurate dimensions for rectangles, outer edges and inner edges for screen. There is a third rectangle between them as construction to mark the place for legs where the led holes should be.
I created the 2nd sketch on it. Same plane and origin but an other sketch I used the edges of the construction rectangle to create the l shaped legs for screen.
In 3rd Sketch, I used the rectangles of 1st as markers and created holes. Once finished i started extrudin.
1st sketch extrude the face plate 2mm> body 1, 2nd sketch second extrude legs>, body 2,3,4,5, 3rd sketch Cut holes to object face of body 1. Then fillet etc.
As everything went well I started to design the second component the box. I wanted to copy the rectangles from 1st sketch of the other then I realized that it is empty. When i select 2nd one all the rectangles and legs are there. When i select body 1, both sketch 1 and 2 become highlighted. Some how all the content of 1 merged in to 2.
I double check visibility and it is not that. Tried to trace it back in the time line but i can find when that merge took place. During selection of cuts it asked me to if i want to capture positions but i chose not to. And even if i delete al the timeline until that cut/extrude the merge was there.
As the part i printed OK now i want to delete the sketch and timeline entries with legs and print the final version but i can not.
Can someone explain why and how that merge took place and advice me whether if this is something I should be worried/ careful about in my designs.
It become a long post. i am sorry. I do not know how to post the files here.
Thanks.
