The ability to select anything stops working until I restart Fusion 360 (macOS)
Often times when I'm trying to select specific entities, like faces or edges, the select tool won't respond at all. It doesn't highlight any of the entities, and when I try to select something anyways, it doesn't do anything. I noticed it also locks up the X-Y-Z camera tool in the top right, because I can't choose an axis or the home view.
I've been having this problem the entire time I've been using Fusion 360 (I'm new). Happens nearly every day, and it's getting really frustrating. I'm on macOS (Macbook Pro) with Fusion 360 version 2.0.3034. This problem has been experienced on both my work laptop and home laptop. One is a 2015 model MBP, and the other is the 2016 model.
This just happened when I was trying to build a sketch, and I wanted to project some other elements onto the sketch. It was completely unresponsive. But it hasn't been limited to just sketches. For example, I was trying to add a fillet to an edge a while ago and I was unable to select the edge (or any other edge, or any body, etc).
The only work-around I currently have is that I must choose the select tool from the drop-down, and then it will work once, before going back to not working at all. It does not work if I use the "select" button on the toolbar. It must be from the drop-down next to the button. Beyond that, I will restart Fusion 360 to get the functionality back.
Has anyone else experienced this? Know of a fix? I really enjoy Fusion 360, but this bug is making it increasingly difficult to work with.
