Tangent between two curves
XDGFX
XDGFX
I was using Fusion 360 last night and ran into an issue - I am unable to create a curve which is tangent between to curves. For reference, below is a screenshot from NX with what I want to achieve
Left: One curve is tangent to two other curves. Right: curve is NOT tangent to two other curvesLeft: One curve is tangent to two other curves. Right: curve is NOT tangent to two other curves
No matter what I tried I wasn't able to select both inner and one of the outer curves when making a tangent selection. If I trimmed the outer curves to length, tangent was allowed but it would move the outer curves from the position they were in - and if I fixed the outer curves I was not allowed to select them for tangent!
This seems like something fairly basic that should be possible. In short; we should be able to make any curve tangent to any other curve or line, even if the ends of each curve are not coincident (see the example below)
Middle curve is not touching lower curve, however it is still tangent to itMiddle curve is not touching lower curve, however it is still tangent to it
Maybe I am just missing something, but if not this really should be added!
Replies (10)
g-andresen
Is it possible that any circular arc, between 2 other (fixed and certain) circular arcs, is spanned in such a way that it is tangential to both?
Circular arcs and their tangential conditionCircular arcs and their tangential condition
günther
HughesTooling
@XDGFX  Can you export your problem design as an f3d and attach?
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Here's an example of an arc that's tangent to 2 more arcs and doesn't touch, so it is possible in Fusion.
Mark
Mark Hughes
etfrench
I'm not having any problems making 4 arcs tangent in any combination of having a large or small arc fixed.  You may need to Fix/Unfix the arc which should not change position or size in order to create the tangent.
ETFrench
XDGFX
Interesting it does seem to be possible.
Attached is the .f3d - the latest sketch has a curve I am trying to make tangent.
HughesTooling
The reason it's not working is because Fusion can't add a tangent constraint to a point on a spline, you can only add tangency at endpoints.
Mark
Mark Hughes
HughesTooling
Note. The endpoint of the spline and arc need to be connected as well.
Mark
Mark Hughes
XDGFX
Ok, so it seems this is the problem.
I have trimmed the outer curves so I am adding tangent constraints to the end points. If I fix the two outer curves (as shown) the length is also fixed. I can create a tangent constraint on one side, but not on the other as the length needs to change.
If I don't fix one of the outer curves, I get the following:
The unfixed curve is no longer in the position I wanted it.
I need everything on the outer curve to be fixed, except the length can vary (alternatively I need to be able to create a tangent constraint to any point on the outer curve)
Does anyone have any ideas on how to get around this?
XDGFX
Further to my previous response, it kind of looks like you've constrained to any point along the outer curves - rather than the ends points.
How have you one this?
undefined
XDGFX
Aha...
It seems to be because in my case the two outer curves are splines - not simple arcs.
It would still be nice if a tangent constraint could be made but I understand now why there seems to be an issue with creating the constraint.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
