Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sweep on square with fillet changes fillet size
4 REPLIES 4
gabrielcobtell
225 Views, 4 Replies
Greetings,
I am trying to sweep a sketch along a square with a fillet:
But when the body is generated the fillet changes size across its depth:
I need the fillets to be a constant size across the body's depth, but I do not know how to achieve this, and cant seem to find any similar examples.
Any help would be greatly appreciated,
Gabriel
Tags (2)
Labels (3)
4 REPLIES 4
Please attach your model.  At first glance, it seems your have selected an inclined edge, in your profile, which would result in a tapered filleted corner.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Here is the model 🙂
g-andresen
in reply to: gabrielcobtell
If you want the fillet in the oblique corners to be constant, you have to go this way:
günther
gabrielcobtell
in reply to: g-andresen
Thx for the detailed explanation, it makes a lot of sense.
Don’t know why I didn’t think of that myself, maybe it was too late at night 😉
Cheers,
Gabriel
