Fusion Support
Sweep along square path creates unexpected geometry.
3 REPLIES 3
KristianLaholm
99 Views, 3 Replies
Solid Sweep a rectangle along a Square path with "Distance" set to 1 and 0 creates unexpected geometry.
Setting "Distance" to 0,5 and 0,5 creates the correct geometry.
(Or any distances that add up to 1)
Sweep only bottom triangle of profile with "Distance" 1 and 0 creates odd geometry.
File attached.
Edit: Is this me not noticing this before or have this changed?
3 REPLIES 3
This should probably be an error - this is not valid geometry.  You can see what it is doing at .85:
and, you can see that at .9 there is an error:
What are you trying to achieve here?  There are likely numerous ways to get valid geometry in the final result that you want.
Jeff Strater
Engineering Director
@KristianLaholm
Is something like this what you are after?
This started with a question on how to make a Tent shape.
I made a rectangular version using sweep, no problem.
The user wanted both rectangular and square tent.
I changed the parameter for Width and Length to be equal, and then sweep feature created this geometry (no errors).
Is this specific case confusing the sweep feature?
I can get the desired geometry with this change:
Changing the 2 parameters AlongDistance (d6) and AgainstDistance (d7) both to 0,5.
Edit: Attached the design file.
