SW 2024 files not uploading into Fusion 360
umairABV9U
umairABV9U
Is anyone else having issues with bringing in SW 2024 files into Fusion 360? Attached is the test file. It either doesn't begin the translation process or fails. I tried the document as a step file and it upload no problem. But as a 2024 SLDPRT file it doesn't do anything. Thoughts? Thank you in advance.
TheCADWhisperer
@umairABV9U
Do you see a *.sldprt file Attached to your post? (I don’t see the file.)
Try zipping the file first I the*.sldprt file will not Attach.
Do you have a commercial license of Fusion or are you running free personal license?
umairABV9U
My mistake! Should be attached now @TheCADWhisperer . I have a commercial lic of Fusion.
jhackney1972
I too cannot open your SolidWorks file in Fusion 360 nor will it Upload.  Perhaps the file is from a newer version of SolidWorks that is not supported yet.  I tried to open it in Inventor 2024.2, which is the latest, and it gave this message shown below.
@jeff_strater, maybe you can try it and if you cannot get it to open, give it to your Fusion 360 team.
John Hackney, Retired
jeff_strater
I believe that @jhackney1972 is correct.  Fusion does not yet support Solidworks 2024 format for import.  I am not sure when that version will be supported.
Jeff Strater
Engineering Director
umairABV9U
Thank you! @jhackney1972  @jeff_strater for checking for me. I can use a different file format for now.
