Fusion Support
SVG Line extension and resize issues
3 REPLIES 3
RFord7MMGC
101 Views, 3 Replies
I am creating a CNC inlay of the attached file.  Started as an SVG and used line extension to extend all lines. In the beginning worked efficiently.  The longer I worked the longer the software took to respond to a selection.  As much as 10 seconds repeatedly.  Some of the lines I extended were fixed in place others were not so I fixed some of them manually.  Why wasn't every line fixed.  If I had a double line a white dot showed.  Most I could zoom in on and repair.  Others were just out in space and could not be resolved.
Then I tried to resize the file.  Result attached.  What is wrong???
Frustrated
3 REPLIES 3
jhackney1972
in reply to: RFord7MMGC
Would it be possible to attach the original SVG file?
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
RFord7MMGC
Hi John,  I've attached the original SVG.
Thanks for your efforts
Rick
jhackney1972
I created a new sketch from you SVG, it stills has a lot of open profiles but at least you can now scale it, take a little tieme, but it will not fly apart.  Sorry I could not do more but I ran out of time.  I hope it helps you some.  Do not worry about Sketch 1 as it still shows in the background even when visibility is turned off.
Model is attached.
John Hackney
Retired
