Message 1 of 9
12:12 AM
I created a relatively simple svg (in attach) in Inkscape. I then drew a rectangle in Fusion, extruded it, and inserted the svg on the top surface of the body (parallel to the XY plane). This generates a 'Compute Failed' warning, as seen in the screenshot below.
However, if I select the sketch, and redefine the sketch plane to XY, the warning disappears. So the first warning seems to be a bug.
Or is my sketch faulty?
Any advice appreciated.
