Suspected Bug: Can't clear Error warning for toolpath generation. I have to force quit Fusion.
I used some cloud credits to get a 24hr access to machining extensions to try them out. As you can see in the screenshot below, I used the Swarf toolpath for one operation. Despite playing around with the parameters, it gave me a terrible finish on my Haas UMC500, so i decided to just go with a 3d toolpath instead, which meant i didn't need access to the machining extension.
My access to machining extensions has now lapsed. As you can see, the "Swarf" toolpath is therefore locked to me. As you can also see though, I forgot to suppress this Swarf toolpath. This means that when I generate all the toolpaths, i get a warning, which i would expect.
The problem is this though: I can't clear that error by clicking "OK", or the "X" box. I have to force quit Fusion all together.
Thinking about it now, I did run into this problem on another project where I decided to give machining extensions a go.
