- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Please see link above (I hope that works).
As a beginner, I am attempting to thicken a surface for the first time. The object linked is a test of a surface with thickening not dissimilar from what I will eventually create, formed with loft of two profiles and one guide line. The thicken process fails with an error message stating, "Could not create a valid result." The reason for this failure is not clear to me; the surface has no tight corners and is very smooth and the analysis shows nothing obvious.
I've tried a bunch of things: redoing the loft, surface thicken, solid thicken. adjusting the various parameters etc.
My goal is to have a final thickness of .5 mm and to 3D print the result.
Thanks for all help,
Phil
