Surface extruding a line in a specific direction
I drew a sketch line that i want to extrude. for some reason the extrude will only go in the up direction. I need it to go to the side. Is there a way to change the direction of the extrude from a line? I'm sure i'm missing something. Thanks for your time.
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
jeff_strater
Extrude will always go in the direction of the sketch normal.  If you want a different direction, create another sketch, add a line in that direction, and use Sweep.
Jeff Strater
Engineering Director
Thank you for your help. That works.
jhackney1972
Please mark your forum post as Solved since you have received a satisfactory answer.
John Hackney, Retired
