Fusion Support
Super Slow doing everything
15 REPLIES 15
Message 1 of 16
cruzMS9NM
304 Views, 15 Replies
My fusion360 is super slow doing all sorts of tasks... My laptop has a Ryzen 7 5800H and a nvidea rtx3060 with 16gb of ram, when it's very hard to use fusion... I've atached a video of me trying to sketch a simple line on a blank document.
any ideas?
15 REPLIES 15
Message 2 of 16
TheCADWhisperer
in reply to: cruzMS9NM
@cruzMS9NM
Q1. Do you have snap to grid turned on? If yes, do you observe the same behavior with it turned off?
Message 3 of 16
cruzMS9NM
in reply to: TheCADWhisperer
yes, I have the same issues with snap enabled or disabled
Message 4 of 16
cruzMS9NM
yes, same behaviour...
Message 5 of 16
gregorychard
What have you got running in the background?
Do you have any app  that is on the task bar?
All of there takes up your ram, hence slower performance especially in fusion whom use a lot of resources.
Goto task manager, control+ault+delete and close down any unessential programmes. Dont forgets to unplug the programmes on the task bar.
Then restart the computer and click on don't open any programmes.
Hope that this will help.
Greg
Message 6 of 16
cruzMS9NM
in reply to: gregorychard
Every thing else is closed, RAM is at 40%
Message 7 of 16
HughesTooling
I think your CPU has built in graphics so do you know if Fusion is using the built in graphic or you NVidia card? If you look at the graphics diagnostics in Fusion does it tell you which driver it's using? You might also want to check the NVidia card is setup for performance over power saving.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 16
cruzMS9NM
in reply to: HughesTooling
I have the integrated graphics card disabled and performance mode on the Nvidia with the charger always plugged in.
Message 9 of 16
HughesTooling
Have you tried the other graphics drivers in Fusion?
Mark Hughes
Message 10 of 16
cruzMS9NM
Message 11 of 16
HughesTooling
Did you try the DirectX 9.0 and OpenGL drivers in Fusion? Also are all the drivers for your laptop up to date? If you have task manager open while working in Fusion are any other tasks using a lot of CPU?
Mark
Mark Hughes
Message 12 of 16
cruzMS9NM
The CPU is at 30-40%
Message 13 of 16
HughesTooling
Is that just Fusion or other processes as well?
This is what I see while sketching, so seems odd you're seeing 40%!  If only Fusion is using all the CPU what do you see if you expand the Fusion process? What is the CPU usage when Fusion's idle?
Mark
Mark Hughes
Message 14 of 16
cruzMS9NM
When fusion is idle the CPU is at 20% +/-
Message 15 of 16
HughesTooling
What process is using the 20%?
Also does the advice to turn off the high resolution setting in preferences in this post help?
Mark
Mark Hughes
Message 16 of 16
chris.eganY2EK3
I just want to chime in and agree that fusion runs like crap since the last update. the longer the program is open the slower it gets. I used to be able to leave it open for days on end, opening and closing dozens of files. Now I can't let it run a full day before it gets so choppy it's unusable. Exact same settings as before the update, same background programs.
It gets worse when you're working with models that have 3d electronics models added, even when those are rendered in "fast" settings.
Ryzen 5900x, 64gigs ram, 3070, this machine should have zero problems running fusion, and it never did before this update.
