Announcements
Suggestion Needed
smahmu10
Suggestion Needed
smahmu10
I need an information.
In my fusion 360, currently I am seeing all the things in mm unit. I want to change the mm unit into the nm unit. Can you please tell me how can I change that?
Thank you,
Samira Mahmud.
jhackney1972
I do not believe this is possible.  Nanometers are on supported as a modeling unit of measure.  You will have to enter the decimal equalivant with the units set to millimeters.
John Hackney, Retired
jeff_strater
also, modeling at such a small scale is not recommended in Fusion.  You will see inaccuracies in the model, and strange behaviors in dimensions, etc.
Jeff Strater
Engineering Director
