After yesterday's update, I noticed that some joints in a sub-assembly were not used in its parent assembly. It's something I never had before so I thought it might be useful to ask for a bit of help.
I made a short video with some test assemblies to show you this weird behavior.
This video is showing the sub-assembly first, I show the movement that was intended (a simple swing arm with the shock following [the spring is floating]). And then I insert this assembly in an upper assembly and after grounding the proper parts, I try to animate it but the shock is not following the movement anymore. It seems that the cylindrical joint that was used on the lower shock axis is not considered anymore. Are you aware of this bug? Or did I do anything bad?
Thanks in advance!
Gil
