Fusion Support
Stuff disappearing from browser / file.
2 REPLIES 2
oeyvtoft
62 Views, 2 Replies
For some reason the content of components disappear from browser / file when doing some operation that is, to my view completely separated from the affected components. I've gone through undo / redo and found the command that seem to trigger the strange behavior, and in one case it's simply activating a sketch. See sample below. Any help would be appreciated very much.
2 REPLIES 2
g-andresen
in reply to: oeyvtoft
activate primary component
günther
oeyvtoft
in reply to: g-andresen
Thanks for the reply- However, I don't understand how that solves the problem. Can you explain?
