Announcements
Student's lathe toolpaths are reversed
rward6UQG7
rward6UQG7
I have one student whose account is doing doing the lathe ops in the reverse direction. He has he set up correct. It doesn't change if he logs onto a different computer. I was looking in his preferences and don't see what he could have changed. For example, during a facing operation it starts at the center of the stock, leads into the stock, and turns from the ID to the OD. It probably is something simple, but it's got me stumped. Thanks.
Accepted solutions (3)
HughesTooling
Check were this marker is on the simulation controls. If it's to the left of centre the sim will be backwards.
Mark Hughes
Owner, Hughes Tooling
rward6UQG7
Thanks. I will take a look at that this afternoon when I have the student in class.
seth.madore
It's most likely this
Seth Madore
rward6UQG7
Yep, you were right. Thank you!
