Announcements
Student account access
i had recently got 1 year student access till 25 June 2022 for fusion 360 but when i signed in my fusion 360 design software with my account is was showing Expired : subscribe now  and the tab is in read only mode please help in rectify this problem
i had recently received the one year student access till 25 June 2022 but when i was signing in  fusion 360 it was in the read only mode and showing Expired: Subscribe now  on top right corner but i had already got access for 1 year . I don't understand what to do please support me with this issue
sasikanth.kollipara
Thanks for using Fusion. Sorry for the inconvenience caused. Could you give a try opening your student account in the web interface and see if you have got the student entitlement available on your Fusion account. This is just to ensure if the Fusion build you had needed reinstallation or it is your account still takes time to reflect for your student activation.
Btw, I hope you received an email from Autodesk about the student account confirmation. If so you are all good to check the above case.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
##- the problem did not solved still my tab in fusion 360 is showing read
only and Expired Subscribe now-##
TheCADWhisperer
Did you log into Fusion with the correct account?
What do you see at http://manage.Autodesk.com
sasikanth.kollipara
@Anonymous I was asking you to check on the web account or like @TheCADWhisperer check on the manage page to see if you have got the right entitlement there.
This will ensure to know if the problem is with the Fusion build you had installed or with the account itself.
Sasi
 Sasikanth Kollipara
LinkedIn
rtrabig
Observer
Observer
I have the same issue.  I had an education license that expired.  I renewed the licenses and when I go to the products and services page it shows.
1 seat - education - single-user  under licenses
When I login to the desktop I get the read only "Expired subscribe now" message
