I created what I would consider to be a fairly basic sketch. Its really just a very simple plate with several holes in it (see below). During extrusion the sections I want are selectable, and show as such. But once completed a section of my new body is non-existent.
My first solution was to add the line intersecting the lower pair of circles. But the problem persisted. That lower area does have a projection from another sketch in it. In order to easily establish a center point (its very hard to see as its 0.25mm smaller than the the circle of the correct size).
Not sure if this is a bug or incompetence on my part. Never had an extrusion fail like this. Without throwing an error/warning as to why.
Any help/insight would be greatly appreciated. Thank you!
