It looks like the constraints and relations in Fusion 360 changed in an unwanted way.
In the past, you needed to explicitly project entities from bodies and other sketches into a sketch in order to put a relation or a constraints between those.
But with the latest Fusion 360 update, this changed.
As an example, here is a body that I created:
I created a sketch on top of this body (a box) to create a lid and I projected the outer perimeter and the location of the 4 mounting screws. When drawing the holes for the screws I noticed that unwanted constraints were created automagically by F360 and I also see a lot of features of the body popping up as highlighted items when I draw on the sketch.
To give an idea of what I mean, I have hidden the body from the view and moved the mouse over the sketch:
As you see, the inner perimeter of the body is now highlighted.
I somehow like this a bit over the old way of putting constraints and relations but it's getting annoying as soon as I discovered that, especially on the mounting holes, it is getting very difficult to draw a circle without getting constraints that should not be there at all.
And this is just a simple part. I imagine that it becomes more and more difficult when the part gets more complex.
Is it possible to disable this feature ?
And can new features like this not be switched off by default, giving the user some documentation on how to enable them ? This is similar to the new grid and grid snap settings where I have to search the internet to figure out how to get Fusion to behave today in the same way it did last week.
Rob
P.s: Just to get an idea of what I am creating, this is the 3D view of that body, a housing for an LCD module:
