Strange bug when exporting assemblies as one .stl file per body
simonvonschmude
Message 1 of 1
simonvonschmude
The Video describes my problem the best.
So basically I have an assembly with components that were created through an R-Pattern.
In this example, let’s assume that I create 3 instances. If i were to export the entire assembly as multiple .stl files (option “one file per body”), I would get 9 files, because Fusion for some reason multiplies the R-Pattern instances with themselves (so if I had applied the pattern by 10 times, I would get 100 Files!).
This doesn’t happen with .obj files, but for those you can’t set the quality of the tessellation.
Any fix for this weird behavior?
Replies (0)
