STP files not uploading
aidaa
aidaa
As title, when uploading a STP file the progress bar is never more than 50 %, if it does upload when I try and open the file I get an error message telling me the file failed to download ?
HughesTooling
What happens if you just use Open, Fusion has local importers for STP, SAT and IGS.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
I Open fails as well, can you share one of the STP files here? You might need to ZIP the file before attaching.
Mark
Mark Hughes
aidaa
Hi
I have opened them sucesfully using the open file method, its just stange as its always worked great and is easier with alot of files.
Thanks for the reply
davebYYPCU
Same for me, Uploading to the Data Panel, failed, about 50% of the progress bar.
Open - failed with a timeline message that was not displayed long enough to read.
Open from hard drive crashed Autocad 2018. (to delete one side for file size.)
Alternate file as obj, is the same result.
256Mb, and NDA involved.
Any ideas.
HughesTooling
With an NDA makes it hard to help. Do you know what's in the file, Fusion only supports surface information in stp files but I think you can have meshes and definitely sketches that Fusion can not read. I'd try open in Rhino as it's pretty good at reading most files and will at least read what it can translate and ignore the rest.
Mark
Mark Hughes
davebYYPCU
I have opened smaller files from same source, surfaces and no sketches.
inquires pending with source for half the model as it is symmetric, (aircraft) and or strip out the unnecessary detail.....
will be a time out or local memory limit as best guess, have same subject files as obj, and Stl, working, but step is not behaving,
Thanks anyway.....
