Fusion Support
stock to model measurement in simulation not working for me
2 REPLIES 2
patl1
118 Views, 2 Replies
I am trying to use the stock to model measurement in simulation to verify the overcutting if the contour and it is not reporting the correct value (-.005), rather it is a larger number that varies as I move the mouse across the flat contoured surface. The stock to model measurement works fine when I am not using a negative stock to leave, but when I am using a negative value to overcut the material, it is not reporting a correct value
2 REPLIES 2
HughesTooling
in reply to: patl1
How about using Comparison? The green area on this electrode is -0.075mm same as I've set the Leftover Stock.HughesTooling_0-1682784212757.png
Mark Hughes
Owner, Hughes Tooling
patl1
in reply to: patl1
I presume you set the leftover stock to the negative amount you believe you are cutting to. Then play with the value to see where it turns red?
The above seems to be a work around for the "stock to model" inspection tool. Are you able to get the program to do what it is intended to do with the stock to model inspection?
