@ahhsks wrote:
1. His post title is: “STL to DWG Conversion” .
1a. Also his initial question, directly related to the post title, is my exact question, .
2. The initial question has not been answered btw. Yada yada: hence my “bumping it to the
3. if you think it would help you?
1. Ah but reading the thread it turns out that the OP was going down the wrong track.
1a. Yes, but better forum form is to start a new thread and provide link to reference topics. (especially since this topic had been marked solved and on top of that the OP was going down the wrong track).
2. The initial question turned out to not be the "correct" question to be asking, and in any case - the question had been marked as solved.
3. I don't need help converting stl files to dwg.
4. Technically - you have posted to the wrong forum, your question should be posted over here in this forum.
I'm just here to help, I think we are getting off track to solving the stl to dwg problem.
