03:45 PM
I've got a fairly detailed STL file which I want to make solid. It's a relief surface with a flat bottom. The relief surface stitches fine, but I cannot patch/stitch the rectangle on the bottom to create a solid.
I also tried using the surface to split a solid block, but that did not work either.
Any suggestions on how to make this solid?
