Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
STL export or save fails
m.hageras
m.hageras
I'm trying to export to STL for 3D-printing and it keeps failing.
I have exported several models before, but this one keeps failing. I have tried three different ways, all of which fail.
- the "Export" which starts an export job - fails after a long time of trying. Seems unusually slow.
- right clicking and selecting "Save as STL" - fails when I click OK
- selecting 3D print - fails when I click OK
The model is a vase with ribs. It's not overly complicated I think. I have made other vases which were equally complex and they exported fine.
This is the error message:
Error: Autodesk Translation Services failed to translate the current document to stl file!
Error: STL Translator failed to export data
Here is a link to the model:
https://a360.co/2C9vIEl
JeromeBriot
It seems to be a bug with the binary format because the export works if you select ASCII format:
If you really want to export a binary file, you can use my add-in 3D Print Plus (see in my signature below).
